OK... I am very new at this, but have learnt a whole lot in the FAQ's... but I am still stuck
What I got:
Computer:
Win2k, lots of hard drive space, Lite-on 40x12x48 burner.
Tmpegenc, Virtualdub, Vcdeasy, Nero 5.5.8.0 (came with writer)
DVD player: Koss KD260-2 (yes, I have enabled the VCD option)
I have 3 other VCD's that a friend made for me, they work... So I know it will play VCD's
I have tried to make a VCD on my computer, little sucess
History
Made a VCD in Nero, it converted the movie and burnt the disk - no work
Made a SVCD in Nero, it converted the movie and burnt the disk - no work
Made a VCD in Nero taking off the CDi mode it converted the movie and burnt the disk - no work
Took my movie file following the FAQ on here took the audio out, used Tmpegenc (but after noticed that I didn't change the FPS or the resolution<duh>)to make the mpeg, used Nero to burn it - no work
Used Tmpeg and only did 2 min of the movie with the correct res and FPS, used Vcdeasy as a V1.1 VCD and it worked <WOOHOO, I did a little dance, the wife looked at me like I was crazy>
So, I changed the end marker in Tmpegend to do the first 60 min of the movie, and then burnt the CD with Vcdeasy as a V1.1 VCD and sat down to wach my movie (part 2 was just about done being made)It didn't work
So, what do you guys think I am doing wrong? Any idea why it would play a 2 min clip, but not read the 60 min CD? It fit on the CD no problems, no errors when it was burning...
Thoughts?
Thanks!
~Brian
I have the same burner and i find that burning over 8x makes it suck. when i get up to 40x it doesnt work period. now I use 4x to burn with.
First I suggest verifying that you can play your created VCDs with a software player (see the tools section) on the PC.
I also suggest you try authoring/burning with a trial copy of Ulead DVD Moviefactory (www.ulead.com). You can still encode using TMPGEnc and import into DVDMF, or let DVDMF do the encode.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
What do I need to do for making backups to play on PS3(japan)
By korazy in forum DVD RippingReplies: 4Last Post: 27th Dec 2008, 13:50 -
Making a HD home video. How shall I play it? Xbox 360? PS3?
By Colmino in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2008, 22:01 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20
