I´m capturing with ATI AIW 128PRO and I need do a VC with some music clips. How can I do a VCD with chapters?
please
thanks
Get VCDImager (dos/command line) and VCDImager GUI. Both can be d/loaded from the 'Tools' links on the left.
You can make a form of "chapters" for standard VCDs with VCDImager 0.7.0+, VCD Toolkit and VideoPack4.
Chapters on VCDs and SVCDs work the same way.
S/VCD chapters don't work as well as DVD style chapters.
Regards.
Michael Tam
w: Morsels of Evidence -
What utility are you useing to burn your vcd's? With Nero5.5 you can select Enable Menu then you have the option to select a picure for the title screen. I'm still testing what each thing in Layout actually does but so far I've just selected 6 thumbnails to see what I get. What I do know is when you drag the file onto the vcd layout. Right click it. Go to properties. Click Menu.Then drag the bar to select the image you want and click OK. I've only done a couple of these but so far its worked for me.
Chapters being jumbled up
By Antony in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 26th Sep 2011, 01:52 -
chapters
By natty in forum Newbie / General discussionsReplies: 0Last Post: 23rd Feb 2008, 12:42 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
DVD Chapters
By Angela in forum Authoring (DVD)Replies: 12Last Post: 6th Jul 2007, 19:37 -
Chapters or Cells
By wulf109 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 16:40
