Can anyone help me out with how much cropping and such I need to do when I capture like this. I'm having trouble keeping the correct aspect ratio. The capture is with VirtualDub at 352x480 using mpeg4v2 codec@6mbs video/8 bit stereo PCM audio@44.1hz. The only filters I apply during conversion to mpeg are for contrast and brightness adjustment+de-interlace and then frameserved to tmpg encoded at 352x240 and I've been trying to do the re-size in tmpg. Can anyone offer a sugestion or two about keeping aspect ratio? Thanks!!
Since you are doing a custom capture in vdub why not use the vertical reduction available in the same menu panel. As I recall, it has a bicubic option that works well and your output from vdub will be 352x240 even though the capture is at 352x480.
There's not much to do but then I can't do much anyway.
Vid Caps
By moonshadow in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Feb 2012, 10:31 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 01:05 -
My Caps Come out very Blurred
By zxfactor in forum Capturing and VCRReplies: 9Last Post: 17th Feb 2009, 07:10 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 12:48
