Hi!! If anyone can help me, I'd really appreciate it. I am trying to take a large MPG ( VCD format ) file and edit it ( or cut it ) into little pieces ( or chapters if you will ) in order to make a VCD with chapters ( and a nice menu w/NERO ). What program can help me "edit" the MPG file? I tried TMPGENC but it only works ( and very good I might add ) with my AVI's. Thanks in advance.
For basic cutting and joining, www.vcdhelp.com/tmpgencedit
To make "real" chapters you dont need to cut the mpgs at all but you cant use nero then, http://www.vcdhelp.com/author#menu -
Cutting the MPG is unneccessary for making a VCD with chapters. Simply load your Mpeg into Virtualdub. Search your mpeg for the spots you want chapters to be. When you see a point you wish to make a chapter skip, write down on a piece of paper the frame number of the chapter location. After you find and write down all your spots, open VCDEasy(obtain it from this site if you don't have it), and load your Mpeg into it. Then, after it loads, select the button that says Chapters. Then on the line that reads "Create a Chapter at frame" place the frame number of the chapter skip you wish to add and hit the OK button next to it. Repeat this step until all of your chapters are added. Then(unless you want to add menues as well), press go & burn your VCD.
Got it!! Thanks for the different tips!! I guess it wasn't as hard as I thought to begin with.
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
sony vegas large file to smaller same quallity
By edy_smf in forum EditingReplies: 2Last Post: 19th May 2011, 10:24 -
movie to mpg for dvd by toast too large; "keep in" been ignored
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 14:26 -
Dividing a large file into chapters how?
By ZedFighter in forum EditingReplies: 0Last Post: 5th Sep 2008, 17:00 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
