I'm a complete and total newbie to all of this, so please bear with me.
The other day I bought a CD-RW drive and was playing around with it. I recorded some MPEGs to a CD and tried playing it on my DVD player, but the MPEGs don't show up. Can somebody help me out here?
Thanks.
They have to be VCD or SVCD (check here for info)
http://www.vcdhelp.com/vcd
You then have to check whether your DVD is compatable to paly VCD/SVCD/CDR (check here).
http://www.vcdhelp.com/dvdplayers"Today is only yesterdays tomorrow" -
Thanks for the speedy reply.
Actually, my DVD player does play VCDs. I have some and they work. But I think it's my method of recording the VCDs is faulty. Like it should be .dat file or something.
I'm downloading VCDEasy right now, so hopefully that'll work. -
Make sure that your DVD is also CDR compatable because it may play factory VCD's but not CDR's.
If you get Virtualdub,TMPGE and VCDEASDY.....you have the best combination of free video editting/converting/authoring sftware that you need."Today is only yesterdays tomorrow"
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 03:54 -
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 06:26 -
A DVD player that will play homemade DVDs without any glitches?
By DaneClark in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jul 2010, 07:26 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 12:37
