Hi All,
Bought this card a couple of months ago after struggling with a PCTV card. It came bundled with WinDVR, which worked OK with capturing to VCD and SVCD, but would always crash when I tried to capture straight to DVD (PAL). Apart from that, the card is a great improvement.
Anway, I happened to check their site today and there's a free upgrade to WinDVR 2.0! When I downloaded this and tried it, I was amazed. No dropped frames, no sych issues and no crashes. And what's more, the resulting file looks as good as the old Vdub>TMPEnc efforst I used to put out, and all done in real time.
Please bear in mind I only capture crappy old VHS tapes (I want my collection of odds and ends transferred to DVD), so I only get a picture as good as the one that goes in, but if that's your intention too, get to their site and download the new version of WinDVR!
I realise that this post is not much use to the great majority of you, but I hope it helps someone.
Thanks as always are due to Balrick et al for such a great site.
Hello!
Thanks for the tip. I didn´t manage to find it for free. But I was offered to buy it with a discount. Perhaps you could share the web adress where you found it or mail me the file direct.
Thanks in advance.
//Lars -
Here it is Lars.
http://www.terratec.com/support/drivers/cinergy_drivers.htm
Hope this helps
Zippy
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Cinergy HTC USB XS HD for DVB-C and SmartCard reader for Conax card
By XSIDE in forum DVB / IPTVReplies: 1Last Post: 12th Sep 2008, 13:08 -
Does TerraTec Cinergy Piranha support MPEG-4?
By technofranki in forum DVB / IPTVReplies: 2Last Post: 9th Jan 2008, 11:28 -
convert VHS into DVD by using Terratec Cinergy XS ?? HELP !!!
By laptopuser in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2007, 20:17 -
Terratec Cinergy 400 capture card
By abbymat in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 23:59
