What is the best way to convert from DVD to VHS?
I have both the Apex AD-3201 dvd player (hackable via remote) and the HP DVD-Writer DVD200i drive with a NVIDIA Geforce4 MX 420 with TV-out.
Do I need an RF adapter? Also, do I need a video and an audio cable?
Thank you in advance.
Hmmmm....maybe I am missing something more here, but sounds like a simple hook video & audio cables fron DVD to VHS and hit play and record. Hopefully DVD player is macrovision free or picture will be screwed up or VCR will not record at all.Originally Posted by wineberry
Like stated above if your apex is hacked with no macrovision just plug it in strait to your VHS this would be your best bet and you would get the best result.
Previously, I was not getting a picture from the DVD player because I did not choose the video input source.
I disabled the macrovision and selected region code 9 on the DVD player.
However, I cannot record on VHS from DVD. When I play the recorded VHS, I get nothing but static.
What am I doing wrong? -
Have you ever recorded using this input port on the
VCR with some other video equipment?
On my Panasonic I could only select "video-in 1" with the remote.
So read the manual. -
Thank you all for your help.
I believe the macrovision hack will not work until I get a firmware upgrade.
There seems to be a lot of info. re: this topic at:
http://www.nerd-out.com/forum/viewforum.php?f=2&topicdays=0&start=50
Thanks again.
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Convert old VHS movie to DVD
By sanray19 in forum Video ConversionReplies: 7Last Post: 20th Oct 2011, 14:32 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
convert VHS into DVD by using Terratec Cinergy XS ?? HELP !!!
By laptopuser in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2007, 20:17 -
Convert DVD to VHS !
By homantam in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2007, 02:05
