Hi guys Im the one who had the PAL to NTSC conversion problem for dvd authoring. well i managed to convert okay (finally!) However the DV files I captured in DVD workshop are in 4 gig chunks due to FAT32 limitation, I dont like the way they will be authored as seperate titles so I want to merge the MPEG2 DVD 6000 Bitrate I converted from them into one file. I have about 5 files to merge..
Please can u suggest a decent utility that will do this smoothly without any problems. Please consider that I would like to author this mpeg to a DVD 6000 bitrate
Results 1 to 9 of 9
TMPGEnc, under MPEG Tools. You can merge your M2Vs together.
You could have also used AVISynth to create a pseudo AVI that would have had all your segmented DV AVIs as one. The AVS (the file that AVISynth creates) is only a text file, so the file size isn't anywhere near that of your AVIs. -
it is only about $400 - but you can buy itwith a hardware encoder for $3000Originally Posted by darthbane2k
Why don't you give it a shot and see if you like the results. It joins flawless.
How much does BJ_M think we make? You may also want to try AviSynth if TMPGEnc does not work the way you want it to.
Hello. -
well everyone here uses maestro and scenarist and CCE -- i figured you all were very wealthy .. :)
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 09:47 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
need joining of 2 mpeg2 files.
By snafubaby in forum EditingReplies: 3Last Post: 21st Dec 2008, 16:51 -
Joining Mpeg2 files from the command line
By roden in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 09:02 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 12:10
