Results 1 to 13 of 13
  1. What is the best capture application from DV/firewire to AVI 2.0?
    Thanks in advance.
  2. Member DVWannaB's Avatar
    Dec 2001
    Canopus ADVC-100 (capture) with Scenalyzer (software).
  3. Canapus ADVC-100 is this hardware?
    I already have the firewire card.
  4. Try Adobe Premier or Ulead Visual studio or media studio pro
    Baskaran Swamiappan
    Englewood,CO
    baskis@gmail.com
  5. Thanks for the replay I will check out Scenalyzer and see if it works with my firewire card. They have a trial download on thiere website.
  6. Member DVWannaB's Avatar
    Dec 2001
    Yes, I apologize, that is what I meant to type in my post above. It is a breakout box that plugs right into your FW card. I promise you will not regret getting this device. It is excellent!!!!!!
  7. Do you need it for Scenalyzer to work?
    I read on thier website and they did not have that as a requirement?
    at the moment I have DV - Firewire.
    What does the Canapus do? DV - Canapus - Firewire?
    Is it a hardware encoder?
  8. Just buy any 20 dollar or more firewire card if you are only capturing from a firewire source and use Scenalyzer. Scenalyzer is a very powerful and easy to use DV capture program. Since the original poster already has a firewire card, I suggest using Scenalyzer.
  9. I looked it up Canapus ADVC-100.
    This is analogue to digital Converter.
    DV is already digital you don't need this card unless you are trying to capture from an anolog source like VHS, SAT etc...
    The front has the DV input, I gues it is just passing that directly to the firewire card. Like I said you don't need it just plug your DV directly to the firewire card. Thier are firewire cables that go from 4 pin/DV to 6 pin/Firewire.
  10. What are the limitations on the trail ware ver of Scenalyzer?
  11. I've been following this post with interest because I downloaded Scenalyzer but I can't save my capture so that it can playback thru my system using Media Player, says I cannot open. If I drag and drop onto Premier, it says that this file is an unrecognized format.
    Heres whats happenning, I have an Addonics 1394/Firewire card and under Scenalyzer it registers for capture device with Microsoft DV camera and VCR. I can see the footage while its playing from my camera fine, I can even hit capture, and it will capture. Problem is when I try to use the file, I can't. does anyone have some suggestions or tips? Do I need a special codec or plugin for this?
  12. Try VirtualDub freeware in tools link.
  13. Did you get the trailware?
    What is the limitation I am at work and have not been able to check it out.
