  1. Hi,
    I have encoded at lower bit rate with Tmpeg but after I remux it the audio is out of sync and the video freezes at times and stuttering.
    Where am I going wrong? please help
  2. IFO EDIT remuxing doesnt work well with tmpg and CCE goto to dooms forum , u can find articles on how to edit your ifos if u have transcoded with tmpg or cce AND U WANNA KEEP THE ORIGINAL MENUS.
    but if u use tmpg or CCE u need to remux with a authoing program
    check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
  3. I have searched but did not find anything that helps the matter.
    Any ideas on it?
  4. ok i should have just said this: u cant remux a tmpg or cce video stream with its audio stream with ifoedit....as it doesnt support cce/tmpg remuxing.....if u positivly must use ifoedit to remux u need to use rempeg to transcode.
    what i mentioned earlier about cce and tmpg keeping the orignal menu involves remuxing with an authoring program the editing the old ifo with the new authored ifos using ifoupdate or ifoedit
    so basically if u wanna remux a tmpg encode u need an authoring program like spruce up, maestro, scenarist, etc
    sorry about not being clear earlier
  5. oK but Hoe can I remux 2 langages + 2 subtitles 1m2v with tmpeg tools? It doesn't see the subtitles fils
  6. again, u need to use a DVD AUTHORING program
    heres a list of authoring programs and guides on how to use them:
    http://www.doom9.org/mpg/dvdr-guides.htm
    compliments of doom9 site
