When I start up SmartRipper it tells me that I have ASPI but the ASPI has no access to the drive (my DVD-ROM) and it says "switch to WinIO". What do I do? Can I still rip?
....DUDE!
well... hmm, i think your problem is the installation of your drive... Or you have not connected it correctly OR you have setted the wrong configuration of your DVD drive... (by that i mean, you setted the drive as MASTER and you installed it as SLAVE) (he, i had the same problem, and after messing a while, it all came allright(after reading the boring manual))
I hope i helped ya...
good luckWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
I get the same messages but it still works fine. Rip Away!
Morloc
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57
