The Windows XP Movie Maker saves the captured file as *.mswmm
Can anyone tell me how to convert this to *.mpeg ??
That is the entire project. Now just tell Movie Maker to make you a movie with this project. Select File --->Open Project.
Select your mswmm file. When the program loads the project select storyboard mode. Drag and drop the entire folder onto the storyboard.
Select Save Movie, choose a title. When Movie Maker saves your file, TMPGEnc can load this file and you are off.Hello.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
Vista Ho-Prem and versions of MSWMM
By wguru in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2009, 19:47 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
MSWMM playback on standalone dvd player
By theyr961 in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2009, 20:55
