I am using DVD2SVCD using CCE 2.5
It is working great everytime.
I have some PAL avis that I wouls like to use DVD2SVCD to encode and convery to a NTSC SVCD.
Is there a way to tell DVD2SVCD to using 480x480 as the output instead of 480./576 that is select based on the input?
Is there a way to tel DVD2SVCD to execute pulldown to covert the 25fps to 29.94 fps?
It wouls be nice if there was a way to tell DVD2SVCD that my desired output format is SVCD NTSC.
thanks. Thanks for the DVD2SVCD guides. Great job.
I have been using dvd2svcd and have converted some films successfully the other way round ntsc to pal .With 2 cce crashes out of six .I reencoded these 2 using safe mode and that worked but as for pal to ntsc I think I have read that it does not work the this way round.Just found this try here
http://forum.doom9.org/showthread.php?s=&threadid=35387&highlight=pal+to+ntsc -
idor,
thanks for the reply.
When you are using CCE when and where do you use this script?
thanks again
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 13:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 09:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 15:48 -
Argh! More converting PAL to NTSC!
By Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2007, 19:56
