  1. Does anyone one else have the problem of kazza going to sleep, when its left alone . Im running V 2.0 and everytime I leave it to download for an extended time , I return to find it either displaying "more sources needed" or its d/l at a incredibly slow speed, then when you click the find more sources option it begins to pick up again , if anyone else is experiencing this problem and knows a way round it please let me know.
    Eh!.......don't know why it's doing that, it worked perfectly well on my system !!!!!!!!!!!!!!!
    Jul 2001
    Maryland
    make sure "optimal bandwith when idle" is not checked.
    This will boost the upstream but does nothing for the downstream
  3. Also, if you're running kazaalite, make sure the SpeedUp thing is running--this searches for more sources at intervals you set. I used to have the same problem, and it was annoying as hell. If you like kazaa's ads and popups and don't want to get kazaalite for whatever reason, get MSFK (More Source Finder for Kazaa), it's a much crappier utility than the one for kazaalite, but it'll do the trick too.
  4. I,ve done exactly what you said guys and it seems to of done the trick, thanx guys
    Jul 2001
    Maryland
    P2P programs need to use ur outgoing connection to send packets to the other computer to keep the download alive.i
    If your upload is going so fast u have no extra bandwith, it can't send these packets out as often.
