im trying to rip the vob files from a dvd that contains more than one large vob file. each file that i rip is pretty small. how would i accomodate them all onto one cd? i regularly use cladxp and tmpgede or whatever the encoding program is called. any help is appreciated.
You can use dvd2avi and tmpgenc
http://www.vcdhelp.com/sefy/?id=frameserv1.html -
Clad gives you the option to frameserve if you check this option clad will creat a .d2v file import the.d2v file into tmpgenc as the video source. the .d2v file pulls in the order of the ripped .vob files, add your audio file to the movie and encode. I do it this way and have had very few problems.
I use smart ripper to rip the vobs, then dvd2avi to do the frameserving and tmpeg to encode. then i just burn it with easy cd creator 5 and they all work great in my sanyo dvm-370 dvd player. I just followed sefy's guide on this site and it worked like a charm. the only thing i did differently was that i used easy cd creator to do the burning. The quality is excellent.
Ripping main movie of a bluray and keeping only 1 m2ts file
By fdenis31 in forum Blu-ray RippingReplies: 2Last Post: 6th Mar 2012, 04:29 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
PS3 XBOX360 with VOB file and dvd movie copied
By MOPLASMA in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Sep 2007, 08:40 -
Partially ripping a vob file
By prizi in forum DVD RippingReplies: 1Last Post: 6th Jun 2007, 15:13
