  1. with some movie`s like tijgetje my movie is not in the center of the tv
    its more to the left side of the tv
    my apps. are:
    smartripper
    dvd2avi
    chapterX
    tmpgenc.
    nero
    please help my...........
  2. how about on your computer? was the movie centered or also to the left?
  3. on the computer it`s also , but on the tv it`s more to the left
  4. hey in tmpgenc, under advanced settings...what did you select for image positioning method?
    it should either be fit to frame (preserve aspect ratio) or full screen (preserve aspect ratio) depending on which version of tmpgenc u have...
    also, try to do a rip w/o chapter X and c if the problem shows up...
