I really need some help in putting 2 movies (4 svcd discs) on to one dvd-r.
There is a guide that roughly does what I want to do, but I have not had any success with it. I think that I need to use TMPGEnc to convert the files to a format that goes onto the dvd-r discs. I want to then use a program like spruce or similar (Dont like spruce) to add the required menus. Then copy to the dvd-r.
I really need a good clear guide to help me, if someone has the time and inclination to.
I have have a pioneer ao4 writer and a sanyo standalone which plays everything. I am using ice white 1X dvd-r discs.
Thanx in advance
Quex
Results 1 to 1 of 1
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 09:12 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 12:56 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 17:32 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 08:16 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
