I have movie rm format,but audio sync prob,is anything can be done to
fix it ?
thx
TINRA 1.4f or 1.5 will convert with good results.
OR use rmtool or rmfix to demultiplex the streams, A & V in to seperate files. Then I either remultiplexed & tried TINRA again or used a third party RM>WAV converter on the audio and TINRA on the video. Virtualdub to remultiplex the files making sure the durations match for video & audio.
MOV format from video camera>avidemux>mp4 out of sync
By duhmez in forum Video ConversionReplies: 2Last Post: 7th Apr 2011, 21:36 -
SOLVED:Mpeg2 Video (Movie cilp) to PAL DVD - sync prob using DVDFlick.....
By bahjan in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 11:03 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
