I tried to rip a dvd onto a network computer . when smartripper was searching the dvd it popped up with a message saying "no keys found"
can anyone suggest me what to do. aspi is installed but how can we verify whether its working and correctly setup. help me out please
thanks in advance
Some DVD don't have the vobs encrypted, in which there are no keys to find.
however when i went to the vob files which have been decoded, and tried to open it in dvd2avi and tried to run then i was getting a scrambled image, did the files get properly decoded, how to verify that
thanks -
networked computer? that may not be a good idea...try ripping the vobs to the computer that the dvd-rom is attached too...
also, in smartripper, under options..set key check to "once"..if that doesn't work...set it to "every vob file"
Cant logon to WindowsXP, deleted some registry keys
By chloec42 in forum ComputerReplies: 5Last Post: 14th Sep 2010, 00:26 -
Which keys are simulated?
By blagus in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2009, 08:20 -
Lost CD Keys, need replacement software Freeware
By Mboyle in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2009, 15:32 -
Dual Boot OS use 1 or 2 keys?
By johnhammonds in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:20 -
Controlling which button gets focus when arrow keys are pressed
By kojow7 in forum Authoring (DVD)Replies: 7Last Post: 8th Jun 2007, 16:24
