Hi,
I downloaded a verified movie file. Not realising it was xvid, I used divfix to rebuild the index because I coulnt get it to play on DivX player, WinDVD or Real. I then checked the file with Gspot, where it told me that it was encoded with xvid.
So I tried 4CC code changer, and the file does now play in DivX player, but there is only sound. There is a large line of blocky green pixels at the top of the screen when playing, and the rest of the screen is black.
I know the file was OK, because I could see the start of it when it was viewed as a thumbnail in the folder.
I have installed the Nimo codec
Scoty
NOW I know the solution to this shit.
I uninstalled all DivX codecs and xvid codecs.Then I Installed only xvid to test if it worked and it did but with no sound cause it had ac3 sound.
You can install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then I installed all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that I installed Nimo Pack but unchecked all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow 2002-04-19. Install Nimo from here:
http://www.btinternet.com/~nimosiro/
Now all should work fine!
Avidemux - Why is there pixelation from stream movie?
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2012, 10:20 -
Movie quality is bad after burn to DVD
By ngochan in forum Video ConversionReplies: 4Last Post: 25th Jan 2011, 23:34 -
Movie DVD with bad scratch
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 26th Jul 2010, 13:25 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
my encoded movie is bad?
By just in forum Newbie / General discussionsReplies: 5Last Post: 23rd Oct 2008, 21:53
