I used Nero to burn my vcd. My vcd's audio is perfect, but my video goes 50 mph and ends in 15 seconds. What did I do wrong.
Knowing is half the battle.
Had you tested playing the mpeg file through Media Player first & seeing if it played properly before your burnt it?
I was using Nero and using an AVI file. I think that was my problem
Knowing is half the battle. -
@futoranime. You need to try & give a bit more info for anyone to help you out. For example,what's the name of your capture card? What program did you perform the video capture with eg:Virtual Dub,IUVCR etc.? Do you know what AVI codec you captured with?
There's a setting in Vitual Dub for example to lock the video capture to the audio capture & make sure they match.
The more info you can give,the more likely anyone that's had your hassles will be able to help you out,okay?
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 09:08 -
What's wrong with Sub2DivX!
By kehn in forum SubtitleReplies: 4Last Post: 27th Dec 2008, 12:21 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
