  1. hey i've searched the forums for about an hour now looking for an answer to my problem but i have had no luck. I'm trying to convert an avi to mpeg1 to burn to VCD, and i have to convert the audio to a wav file first. I'm using virtual dub 1.3c to d othis however when i goto the option File.save wav , i get the following error:
    ACM failed to suggest audio decompression format
    AVIOutputWAV:The handle is invalid
    also this might help, when i goto file information the compression field has: unknown(tag2000)
    if u know how to fix this please let me know.
    thanx[/b]
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it is a divx you are trying to convert i suspect .. and the audio is a ac3 file i bet ..
    there was a thread today about this -
  3. yes it is a divX, and im not sure wat the audio is caus eit says unknown....and i looked for that post that u siad was there and i couldnt find it so could u please tell me wat i have to do?
    Jul 2002
    Erie, PA United States
    Select direct stream copy/save wave as "all files" and rename the file extention to .ac3. Then use another encoder such as BeSweet or HeadAC3he to convert the ac3 file to wave.
    Warning! I'm baaaaaaaaack
