is this program good for capturing MPEG2?
If you have a fast system its pretty good. Cyberlink has a demo why not try it for yourself.
It is realtime capture/encode (no temp file and then mpg build like some apps do). I think powervcrI was like that.
It has some noise reduction and softening filters but its either on or off, they not adjustable.
You can tweak the registry to get odd frame sizes like 704x480 or 352x480 that are not available as defaults.
Lots of posts on this one. Search the forum on PowervcrII and you will see them all.
Another app that compares well is Intervideo's Windvr. They have a demo also.There's not much to do but then I can't do much anyway.
good program??
By rko2164 in forum Software PlayingReplies: 1Last Post: 22nd Dec 2009, 04:14 -
Looking for a good editing program
By JCWBobC in forum EditingReplies: 4Last Post: 8th Sep 2009, 11:15 -
I need a good program. Some advice please.
By hellfire45 in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 11:35 -
Good dvdr program?
By chronic777 in forum Authoring (DVD)Replies: 20Last Post: 16th Aug 2007, 10:29 -
Good IM Program?
By Poppa_Meth in forum ComputerReplies: 11Last Post: 10th May 2007, 08:03
