I'm converting a avi (divx) to a SVCD with TMPGEnc. Should I select interlace or non-interlace and what exactly is the difference between the two?
I guess I'll give this another bump. No one knows? Could someone at least tell me what is the difference between the two?
non-interlace
divx movies are always non-interlaced. -
OK, thanks. Does it really make a difference either way, since non progressive scan TVs can only display Interlace anyways?
It makes a diffrence because TMPGenc uses a diffrent set of matrixes for interlaced nad non-interlaced. For progressive encoding it can take advantage of more image similarities.
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 02:33 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
