I have tried to backup two disney movies for my daughter-in-law before the kids ruin them. Anyway,I have use smartripper and clad. Smart ripper says authenication successful, but when ripping, it stops in the middle and says it needs to be redone or encrypted. And the other movie it ripped it, but the first part of the movie missing. On clad the voices were out of sync and it looked like parts of the movie showing up at one time. I did notice the codes were the same C000000001 on smart ripper. I am not very good at techinical terms, so excuse me if I said the wrong thing. It seems like to me they 're stopping us from making copies of our movies. Does anyone have any suggestions? Is anyone working on the problem?
i ripped snow white fine.....
did you play the movie in winDVD/powerDVD first?
what you can do is play the movie for a little bit and then pause it...then you can run smartripper on it.
also, make sure your DVD is spotless.....crap on the bottom can cause problems.. -
What do you mean in windvd first. I played it in my cinemaster dvd player first, if that is what you mean. I also tried to backup Tarzan and Jane too. It was the one with the first part of the movie missing and the voices messed up. Never had any problems like this before.
I will recleaned the dvd and will try again. Thanks!!! -
do u not have winDVD or powerDVD installed on your computer?
try getting any of these proggies...they are great software DVD players.
but anyways, play the movie on your software dvd player for a little bit and then pause it...
then, run smartripper and c if u can rip it -
ok, I used my scratch repair kit and it fixed it. I did get it ripped. I would like to know how to get windvd email me at rdbjab@fidnet.com.
I like smartripper the best. It produces the clearest pictures and don't have to worry about interlacing. I guess I thought the same thing was happening again with snow white since, they had the same codes. I Learn from my mistakes. I have done about 60 or more movies between the movies my son and I have. I am still puzzled about the other movie. thanks -
Originally Posted by scarlet ohara
ripping is basically a simple copy and paste (with decryption) that doesn't alter any of the characteristics of the source (unless you use wrong key to decryt, then there's gonna be green blocks everywhere)
White Bar on itunes rip
By Tylerr in forum EditingReplies: 8Last Post: 24th Mar 2011, 03:49 -
Samsung vp-w70 HI8 problem(white snow) - solution needed!
By 850nm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Jun 2010, 21:07 -
General call - Snow White (Disney) and Laserdisc
By darkbluesky in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2009, 09:39 -
Black/White blocks on DVD playback/rip
By babyshambler in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2008, 14:41 -
Green subs appears on DVD but even when I rip it, on PC i'ts white!!!
By cemman in forum SubtitleReplies: 3Last Post: 21st Jun 2007, 14:57
