Hello, I am new here and at making VCDs. I don't know much so right now I am trying to figure things out.
If my standalone VCD player could only read .dat files, then should I burn my VCD using only .dat file? And does anybody know any MPEG to .dat converter or encoder out there? Thank you very much.
You should not be making DAT file yourself.
A VCD is NOT a CD-ROM with DAT files on it.
All you need are MPEG files that are VCD compliant (e.g., if you use TMPGEnc, make sure you use the VCD template) and an authoring/burning program that knows how to make VCDs.
The acutal structure of a VCD is much too complex for you to be able to make yourself which is why you need an authoring program.
I strongly recommend VCDImager with a GUI like VCDEasy for the beginner.
For simple VCDs, Nero is adequate as well.
http://www.vcdimager.org
http://www.vcdeasy.org
http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How to descryption video.dat file.
By newbievideohelp in forum ProgrammingReplies: 1Last Post: 12th Oct 2008, 22:11 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
