Hi All, i use WinDVR for capture movies from DVD (via my standalone DVD-Player) directly to Standard SVCD.
actually everything functions well, but when i play the movies sometimes are picture errors in the captured movies. it sit, as if the resolution of one second would change on the other one and then return to high quality.
This is very bad. It look how a resolution like 10x10 ( for 1-2 seconds.
how can I avoid that?
