Just downloaded a great copy of signs svcd but can't change to mpeg1 on tmpeng, system keeps freezing won't even load into tmpeng. Any body know of a way I can save to disc.
why are you converting SVCD to VCD? you would be losing alotta quality in the conversion...
Tried just burning to disk but stand alone player would not play it. Any suggestions
did you check dvd player compatibility on this site? it'll tell u which formats your standalone dvd player can play...
if it sez that your standalone can play SVCD, then u prolly burned it incorrectly -
tmpgenc with mpeg2 codec
www.vcdhelp.com/tmpgenc
or using dvd2avi and tmpgenc
www.vcdhelp.com/mpeg2tovcd -
http://www.geocities.com/newestmoviesencode/dvdvcd
try the header trick to get your player to play mpeg2, still burn the file as vcd
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 14:55 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
