    UK
    Hi
    When encoding anything at all to DivX, either either DVD 2 DviX or MPEG or SVCD to DivX, the audio is ALWAYS outta sync.
    I mainly use FlaskMPEG to convert various things to DivX.
    what should I do to fix this problem?
    Please Help..
    May 2002
    Rainy City, England
    This may be the answer.
    There are so many ways to convert to DivX, but FlaskMPEG does seem so often to be involved with sync problems. I use Virtualdub, but there are many all-in-one solutions which will provide good quality, in-sync, DivX.
    Maybe FlaskMPEG can produce good results, but from what I have read, I would choose another path. 8)
    UK
    well its mainly DVD rips i'm concerned about, do u have any software recommendations for converting anything to good quality in-sync divx?
    May 2002
    Rainy City, England
    Well, I would recommend looking at the guides at http://www.doom9.org/, or http://www.divx.com/support/guides/guide.php?gid=2 If you want an all-in-one solution, try http://easydivx.does.it/
    My preference is to use Gordian Knot, which acts as a frontend for Smartripper,DVD2AVI and Aviynth, with Virttualdub for the actual encode.
