Ok here is the deal... I have some vhs tapes that I would like to capture to look like video and then transfer to my mini dv camcorder. My camcorder does not offer pass thru or line in,,, just firewire in/out. I have a pctv capture card which will allow me to capture at high resolution. The problem I am finding is that the captures look like film, not true video. Is there any other solution besides buying a dazzle bridge or Canapus?
thanks,
mark
Results 1 to 9 of 9
Umm...
what do you define as true video? film? it might make more sense if you clarify these points. -
Well camcorder footage is crisp, showing it is obviously video. After doing a capture it resembles movie film. Although it does look nice, I need that video look.
thanks... -
To make it a bit more clear. Some television shows are shot on video, and some on film. When capturing those shot on video, I want to maintain that look. All captures I have done give it that film look instead.
Use an interlaced aware sharpening filter. VHS is smooth you are not going to get the look you are going for straight from the capture. Even using the dazzle bridge it's still not going to improve the signal in the way you are thinking.
I don't know of any for vdub, but you can get the same resoluts by using...
ViewFields
<somehsarpen filter>
UnViewFields
I would recommend the excellent msharpen or xsharpen filter. -
I tried the xsharpen filter... Great results, thank you.... Now here is the other question... Which resolution should I capture at? Since I am going to convert it to DV Avi in ulead video studio 5
Always capture at the higest possible resolution wher you don't compromize the compression or frame rate. So if you can 720x480 @ 29.97 YUY2 or UYVY. Use a compression codec like huffyuv or MJPEG.
Their are how-to guides on this site.
video flicker when capturing from sony video 8 sources
By HidenSeek in forum Capturing and VCRReplies: 8Last Post: 30th Dec 2010, 10:39 -
How can I mark events/chapters in video while I am capturing the video?
By CIguy in forum Newbie / General discussionsReplies: 16Last Post: 23rd Nov 2010, 21:04 -
Video goes to snow with ATI Theater 650 pro capturing through s-video
By Des in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2010, 07:37 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
Which Hard Drives/setup are best for capturing video/video editing?
By Balefor in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2008, 13:24
