hello ..I have been trying to burn a few dvd films which have alredy been copied. I have been using nero 5.5.9.9 but as it caches the files it comes up with an error message saying "cache file too small" but it continues anyway and finishes the burn but the discs only play ok till half way through then they freeze. Am I doing it wrong? I am using win xp and the fat32 file system which only allows file size up to 4 gig...is that the problem??? ....any advice is appreciated....thanks
don't if this will help you, but I have the same problem with freezing and pixelation halfway thru teh movie at first I thought it was my media, but after I switch to a different writing software, the problem went away....so my suggestion is use another software to write it to the disc......right now Iam using Gear pro dvd... and Iam very satisfied with it..
just my 2 cents...hope that helps
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 11:40 -
print problem with nero
By suepete in forum MediaReplies: 0Last Post: 31st Oct 2007, 16:52 -
Nero Problem
By alley04 in forum Authoring (VCD/SVCD)Replies: 3Last Post: 6th Sep 2007, 18:08 -
problem with Nero
By moe_b_disc in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 05:13
