Hi All,
Wasnt sure which forum to put this in so thought here might be ok.
A while ago i found a program on download.com that when run you could right click on an mpeg type file and if it wasnt running it would tell you which codec you needed to download for it to play . Sadly i lost the program and cant seem to find it anywhere !!!! Anyone got any idea the name of it and where i can find it these days ?
Many thanks all , i appreciate it![]()
Jon
Results 1 to 9 of 9
I only know an app called "G-Spot". It tells you what codec a movie uses and it also lists the codecs installed on your machine. Not as comfortable as the one you're referring to, but better than nothing?!
Ah, I have heard of the g- spot but up until now i have failed to find it,any tips on finding this elusive little chap greatly appreciated
I know this sounds bad and i agree with Micko , but i cant find it (Ok ok stop the giggling...hehe) Can you point me in the right direction as it sounds a handy program.Originally Posted by darkobserver
Thanks for the help , and glad to see im not the only man to have trouble finding it
Jon -
Well done, guys! Sorry, I saw your question just now 8) Hope, everyone is happy now.
Yeah thats great Dark , many thanks . Not the program i was looking for but as near as can be and a good program to haveOriginally Posted by darkobserver
Thanks again,
Jon -
I believe the utility you are referring to might be MPEG Properties.
http://www.afterdawn.com/software/video_software/video_tools/mpeg_properties.cfm
I use GSpot for AVIs and it works well, particularly where audio codecs are concerned, for identifying MP3 VBR and AC3 codecs.
Duplicate Finder program
By Han Solo1 in forum Off topicReplies: 2Last Post: 17th Jan 2012, 21:34 -
Video error finder
By almozayaf in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2011, 15:47 -
Driver finder software W7
By neworldman in forum ComputerReplies: 5Last Post: 28th Jul 2010, 22:24 -
Hi-Def Camcorder with view finder
By telerover in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2009, 04:00 -
Best Sat finder?
By snadge in forum DVB / IPTVReplies: 0Last Post: 22nd Dec 2008, 10:03
