Hi all,
I've developped a forked release of the original VCDxBuild by HvR. Today I may tell you it's finished and published.
Please try it out, you can download it at : https://sourceforge.net/projects/lkvcdimager/
Compared with the original VCDxBuild, I've added support for ISO9660-2 (level 2) characteristics, meaning you now can create advanched (S)VCD's with ISO9660-2 custom files in the ISO-track.
For those who doesn't know the difference in the 2 levels of ISO9660, ISO9660-1 is restricted to max 8.3 chars for filenames, 8chars for directories and all in uppercase.
ISO9660-2 allows you to use longer filenames : files with or without an extension (max 3chars) and directories without an extension (this is the same as with ISO9660-1) but the maximal length of a dir/file can go upto 31chars.
This is not realy compliant with ISO9660-2, but I added also support for lowercase characters in dirs/filenames. It seems to work propperly in WindowsNT4 and Windows2000 (it should be in linux too).
Though DOS capable devices still can read the filenames of those with longer names, it just convert it to the 8.3-standard using the '~nn' at the end of the file
There are no major changes to the building of the actual (S)VCD. A disk created with lkVCDxBuild still works propperly in a standalone DVD-player (as if it was created using the original VCDxBuild). Though I've done some major optimalisations in the original code to let the application work faster.
This release is targeted for the win32-platform only.
For anyone who wants to have a portable version, please read the accomponing ReadMe_1st.txt file in the download.
Regards,
Final Release of lkVCDxBuild rel. 4.0.7.10 has been published.
Also the latest release of lkVCDimager, the library which has lkVCDxBuild internally integrated.
lkVCDimager is now fully multi-threaded, no more memory leaks could occur (you must try very hard to get them).
lkVCDimager is now also integrated in the newest release of VCDwizard 2.6.0.0
Visit http://lkvcdimager.sourceforge.net/ to get more info. -
Latest release of lkVCDxBuild 5.0.7.10 published.
Michael Tam reported that rel. 4.0.7.10 did not allow one to use unreferenced selectitems.
That's been solved.
Fairuse 3D released...
By MothMan2 in forum DVD RippingReplies: 4Last Post: 18th Apr 2011, 20:08 -
Avast 5 Released...
By Poppa_Meth in forum ComputerReplies: 11Last Post: 29th Jan 2010, 14:48 -
AV Linux 3.0 released.
By GMaq in forum LinuxReplies: 9Last Post: 14th Dec 2009, 08:38 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10 -
ImgBurn v2.4.1.0 released
By louv68 in forum Latest Video NewsReplies: 2Last Post: 1st Apr 2008, 13:18
