  1. Ive been dabbling in vcd's for about two years now but i recently just bought a new computer good enoght to burn dvds. i used one of the guides on this site until i got to the DVD2AVI part. I've ripped the dvd and then open the vob files in dvd2avi but when i start to decode the film it does the sound but not the picture. Any Idea's???? Please help
    CHEERS>
  2. Hi:
    Can you tell us what are you trying to do? Create VCD, SVCD, DVD, Avi? If your final file is MPG what are you using for the encoding process (CCE, TMPGEnc)?
    What guide are you using?
    THX
    8)
    Rey
  3. when you are creating a project file in dvd2avi, the video will not show up in the display window in dvd2avi...
    if you wanna preview instead, press f5
  4. CHEERS GEEZA'S
