Please tell me what chip you use and the speed Intel or AMD and how much ram you have and how fast if your hard drive
Results 1 to 30 of 31
tee hee. Duron 800 here 128mb hdd is 13gb 7200rpm seagate.
for a normal 93 minute movie from Mjpeg to Mpeg-1VCD takes me about 10 hours with Panasonic Mpeg Encoder. Tmpeg will do it in about 2.5 but with Tmpeg I always get horrible block noise when scenes change. -
P3 700 100 mhz bus 20 GB 7200 WD hard drive it takes 7 hours w/flask mpeg on a 26 minute file
<font size=-1>[ This Message was edited by: VerbatimDVD on 2001-08-19 06:31:43 ]</font> -
Intel Pentium III 600 mhz, 256 RAM, 60 Gb 5600rpm.
Encoding 90 Min DivX to SVCD with TMPGenc takes about 10 hours for me.
Thanx/
Lars -
AMD duron 800 100fsb 384mb pc133 30 GB 7200rpm HD.....for a movie about 90 minutes or so (eg Hackers2 dvd rip) with the standard vcd ntsc template in TMPGEnc it takes me a little less than 3hrs. but i usually make a xvcd so it takes a lot longer than that for mine
P3-1000 Meg/256M SDram, 80 Gig Ultra 100 Seagate.Promise Ultra 100 TX-2. 1 hour clip about 4 hours, no more than that
On my 400MHz Pentium II, with 128 megs of ram, and a 7200 rpm hard drive, it takes me about 10.5 hours to convert divx to Vcd. for a movie of about 95 minutes.
1.2 gig thunderbird 266 bus speed, 512 megs of 133mhz ram, 30 gig 7200 western digital, 5500 voodoo 5.
with TMPGE beta version b use to take 2 hours for a 60min. segment, now I have a MPEG2 encoder, 48min. now takes 48min. then about 4 min. to mux - done.
This is while making a SVCD. Why 48min. thats what I can burn onto the new 99min. CD-R's.
Get it now cause stuff is cheap CPU and EPOX motherboard was $199, Ram $49, hard drive $99. -
<font size=-1>[ This Message was edited by: PimpInDaHouse on 2001-08-24 13:52:54 ]</font> -
1 gig Intel P3 , 128 ram, and a 40 gig Ultra ATA/100 (7200 RPM) About 9 hours for CBR and about 20+ hours for VBR.
Tbird 1.2Ghz 266FSB, 512MB ram. It takes me about ~1x the movie runtime to encode (for each pass) for MPEG2. Been a while since I did a MPEG1 so I don't recall. But for stuff I like I use 3pass VBR so that's 4x the movie runtime.
Note - it depends a lot on your encoder. I mostly use CCE which is MUCH faster than TMPGenc. And MPEG1 encodes faster than MPEG2. -
Hey thxkid!
Where did you buy your combo?
I would sure like to get that sweet deal!!!!!!!! -
1.4 GIG ATHLON,640 RAM.MPEG 1,DVD RIP,2HR MOVIE=ABOUT 3HRS.MPEG2 2 HR MOVIE CQ 70,ABOUT 4.5 TO 5 HRS.
Guest
TBIRD 1.0 GIG ATHLON"OVERCLOCK TO 1.1 GIG ON MY MSI MOTHERBOARD,384 MB PC133 RAM
,200FSB,40 GIG 7200 WESTERN DIGITAL HD ULTRA ATA 66,WITH MY SVCD TEMPLATE IT TAKES
3 1/2 HOURS TO ENCODE 41 MINUTES OF THE MOVIE.I USE 3 CDS FOR EACH MOVIE I ENCODE
AND THE QUALITY IS QUITE NICE.
The System: Gigabtye GA-6BXDS Mobo w/ onboard SCSI, Dual PIII600(100mhz FSB), 512megs Ram, 15 gig 5200 RPM Western Dig. UDMA66(for ripping), 10 gig Western Dig. Ultra SCSI-2(for conversion), 4 gig Western Dig. Ultra SCSI-2(for OS), 6x Samsung IDE DVD-ROM
The Software:Windows 2000, DVD2SVCD with no 48Khz-44.1 Khz Conversion and CCE set to 3 pass VBR
The Video: X-Files Episodes Season 1 & 2 DVD's (approx 45 min per episode)
The Time:4.5 hours per episode to encode
Final Size: Approx 750Megs per episode -
MY SYSTEM;
INTEL PII (CRAP) 128
ENCODER: LSX FULL VERISON
MULTPLEXER: TEMPG
A normal VCD 50min movie takes me about 100min or less
And to mult. the video with the audio takes me about 5min
My system is crap put the speed of encoding is aswome, alot better that TMPEG taking 10 hours for a full 90min movie. -
lol, let the specs fly.
p3 850, 256pc133, 20gb ata100.
ccesp through adobe premiere, using 4pass vbr.
12 hours for 40 minutes. -
There is gonna be a huge difference even with the same systems, due to what is done to the original to bring it to the final encoding. ie filters, original format, final format.
I have a dual P3 1Ghz and 1G of RAM.
If i'm just using TMPGE:
- To convert a 35 min divx low motion 320x240 29.97 fps to VCD NTSC takes about 2hours.
- To resize and letter box to SVCD NTSC takes about 4 hours.
If i framserve from virtualdub to add some filters to adjust the image it can go 8-12 hours.
PII 256Ram UltraWide SCSI
2 hour DivX to xSVCD 2-Pass (2 parts) using TMPGEnc with "Normal" search option and tooLAME for audio = 9 hours (4.5 per disk)
if I up "Normal" to "High Quality" or add a filter then the time per disk goes up 1.5 or more hours
there probably isn't a normal encoding time for anyone - since no one has the exact same method -
my system
Dual PIII 866's - MSI motherboard
512 MB RAM
2 x WD 7200 ATA100 40gig drives on a Fastrack ATA 100 RAID
Windows NT 4.0 Workstation
DVD to SVCD
in TMPGEnc 2 pass VBR with Slowest motion search
and 10 bit DC, audio in tooLAME
depending on movie running time
12-15-17 hours
^_^ -
Mine current system is T-bird 1.2G, 256 MB RAM
for SVCD, it's 5X using CBR or CQ_VBR
for VCD or XVCD, it's 2.4X using CBR or CQ_VBR
I had P2-266Mhz with 64MB RAM
for SVCD, it's 24X using CBR or CQ_VBR
for VCD or XVCD, it's 12X using CBR or CQ_VBR
The hard disk(s) do not come into play in encoding time. I already did the math. Actually it does but very very insignificant.
On my AMD 1.3ghz clocked at 1.45ghz using an ATI All-In-Wonder 32 DDR with 512 megs DDR, the time it takes for me to encode a 25min (highest quality setting, noise reduction, sharpen image, ghost reduction, custom color correction filters included) VCD format takes about 2 hours and 5 minutes. The quality is good on TV... I'd capture with AIW Radeon DDR using mpeg1 with bitrate of 10 (more and I start to see drop frames), then encode it on TMPG with filters and highest quality setting and it does a crisp good VCD!
@villain4hire ... I think going from MPEG-1 to MPEG-1 is a much different story then DVD to MPEG-1/2 or DivX to MPEG-1/2
amd 900 @ 1020
786mb pc133
geforce 2 mx
realmagic dvr mpeg2 encoder/decoder card
2 20g ata 100 7200 rpm fijustu
realmagic hollywood +
sblive value
wintv pvr (just got this one!)
if i use tmpge it takes about 6hr for a 2hr 2pass vbr mpeg2 encode.
With the dvr its realtime so its quick. 1:1 -
PIII 1 GHZ, 512 Megs RAM, WinME
(typical 90 min movie)
60 Min. Dvd2Avi with 48>44HZ(High) and Normalize
135 Min. AVISynth 1.03 with mpge2dec > CCE 1 pass VBR (encoding mpa too) (CCE reports .75 when letterboxing, and .86 for 4x3)
5 Min. Pulldown
10 Min. Mux bbMpeg
30 Min. Burn Nero 5.5.2.3 3 CDs (8x)
__________________________________________________ ______
240 Minutes or 4 Hours
Say, how much are MPEG2 encoding boards? And how is the quality compared to CCE? -
My sigmadesigns.com dvr board runs about $797us dollars on pricewatch .com and looks real good but for lower bitrate encoding nothing looks better than a software encoder. This is basicaly for dvd authoring because it is real time and at a 6000 bit rate everything looks nice on it but it takes to long to do on a software encoder.
athlon 1.5ghz, 384mb ram, Iwill board. the last svcd movie I did was the thin red line and it took me about 6 hours altogether. I do the audio extraction/downsampling/conversion seperately and then I do the video using CCE cbr. the quality is excellent
I USE FLASK I HAVE A DURON 700 64MG MEM 10 GIG HARD DRIVE
I CAN DO A VCD 80 MIN MOVIE IN 2 HRS , HAVE IT ON CD IN 2HRS 10 MINS...SO THAT MUST MAKE ME THE VCD KING
QUEERS
HEY BIGTREE2001 YOUR MY MAN I GOT 32meg RAM 8 GIG HD & IT TAKES ME 50mins FOR 80Min MOVIE & ON 1 CD IN 81 MIN
This is deja vu all over again !!! Iv'e got a commadore 64 and can tape 45 minutes of music in ...er...45 minutes...not tried vcd's yet maybe in a few ...er...years....!
x264 encoding occurs too fast in pass 1
By codemaster in forum DVD RippingReplies: 5Last Post: 21st Sep 2011, 22:28 -
make and save fast motion clips
By Lief in forum EditingReplies: 4Last Post: 18th Aug 2011, 10:33 -
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 12:09 -
I am testing my encodes. They are encoding too fast
By rocky12 in forum Newbie / General discussionsReplies: 13Last Post: 7th May 2009, 03:00 -
fast video for iphone encoding?
By moxie in forum ffmpegX general discussionReplies: 1Last Post: 25th Mar 2008, 23:59
