I am having a problem remuxing with ifoedit, I follow the doom guide make the .d2v project and the tmpgenc template, open the files in tmpg and encode all without any problems, however, when I go to remux the .m2v file with the .vob file ifoedit does nothing I have done this method several time using a .m2v file from Rempeg and it works beautifully everytime, why can't i make it work with Tmpgenc.
Please Help
Are you specifically using the latest version of TMPGenc that can output ttue video only streams or are you just naming the output .m2v? If the latter then you need to de-multiplex the .mpg ( or whatever you named it ) generated from TMPGenc to get the .m2v stream that ifoedit is probably looking for.
Personally, I could never get IFOEDIT to remux (properly) anything created by TMPGEnc. I followed the guides and it seemed to work, but the final results were always jerky and unwatchable. Good luck with it!
Thanks for the fast replies, I am using an older version of Tmpgenc however I don't need to place the .m2v at the end of my file, Which brings me to anther question, I have downloaded the lastest version of Tmpgenc and It doesn't recognize .d2v I look in the drop down menu for supported files and .d2v isn't there. What's the deal??
Thanks -
Try using DVD2AVI to demux. I never have a problem with TMPGEnc recognizing the .d2v file.
Good luck
oh you could dl DVD2AVI from doom9 -
Use Tmpeg to create a DVD compliant mpeg stream with mpeg audio. I find that this allows you to import it into an authoring program stable and with the audio in synch.
well another remuxing problem...
presby,
ive got another thread running that i started couple days ago..
and as far as i know it would be hard for u to get tmpgenc or cce encoded video(*.m2v) to remux using ifoedit(whichever version u use) ...
u said rempeg is working same here and i guess we gonna have to live with for now until someone could get tmpgenc/cce to work properly...
:^)I FEAR NO BEER!!! -
I have no problem with TMPEG when remux. But I always end up with audio out of sync. Why's that?
Use all different version IfoEdit.
Use all different version of TMPEG.
Running Windows XP with or without SP1
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 09:36 -
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 13:59 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
