yo pplz...
i've got this weird problem on my box...
randomly, when i double click a mpeg1 file
to play it in windows media player 6.4
my box will instantly reboot...it doesn't
even get to start playing, i don't even see
media player come up...it reboots as soon
as i double click
it doesn't do it all of the time, only about 1/30
and it isn't a specific file that does it, just any
mpeg1 file
i'm running w2k, i dont recall this ever
happening in win98, but its weird because
the box doesn't just freeze.. it reboots just as
if i hit the reset button
any ideas what could cause this?
thanks,
ftc.
i see this as being 1 of 3 scenario's..
either when you click the mpeg file the power requested from the harddrive or cpu (or both) is too much for your power source to handle so it kicks it in to a reboot.
your harddrive is going bunk, but i dunno.. that usually just freezes the comp..
and then again, you may have a virus.. -
dont really think its any of those things...out of them it would most likely be an anti-mpeg1 virus =]
only mpeg1 files cause the problem, i can do plenty of other stuff fine...dv editing, mpeg2 playing, blah de blah
its just mpeg1 -
try playing the mpeg1 file through a different program such as powerdvd, windvd, maybe even upgrade your version of wmp
Is the error repeatable? By that I mean, if MPG file X causes a reboot, does the SAME FILE cause a reboot every time you try it? Or is a particular file more likely to reboot than some other file - if so, I would guess a corrupted file or failing hard drive. Power Supply is also a possibility.
If the error is indeed random with respect to the MPG file in question, then try a different player as suggested previously. If the error is related to WMP and not the other player, then re-install WMP.
With the low frequency of occurrence, you will have to make MANY attempts to develop a pattern or linkage of occurrence, or to determine if a fix has been achieved. For example, if failure rate is approx. 1 in 30, then you would have to get 50 to 100 successful plays in order to be reasonably certain that you have corrected the problem.
DVD player : Which video file is the most common, mpeg1 or xvid
By iwiiiiiiiiii in forum DVD & Blu-ray PlayersReplies: 6Last Post: 16th Mar 2011, 07:12 -
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 02:53 -
XP - Reboot cycle
By Ai Haibara in forum ComputerReplies: 7Last Post: 3rd Sep 2008, 15:19 -
Only crop mpeg1 file with ffmpegx
By Paedar in forum ffmpegX general discussionReplies: 3Last Post: 23rd Sep 2007, 16:48 -
Corrupt MPEG1 file plays nothing but blue
By croix19 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 02:28
