hi all, I hope someone can help me out. I've been capturing mpeg2 with my AIW 128 for over a year and converting it to mpeg1 with tmpgenc for over a year with no problems, then the other day all of a sudden I started to get the "cannot open, or unsupported" error message. Naturally, I came here trying to find information on this problem. I read that Tmpgenc plus needs to have a third party mpeg2 decoder such as in PowerDVD or WinDVD. I also read posts about the VFAPI plug in settings in enviromental settings. So, I've done the following things:
1. Installed PowerDVD
2. Installed WinDVD
3. Adjusted VFAPI plugin settings
4. Installed mpeg2 plugin for Tmpgenc
5. Installed the nimo codecs
But still after all of this, I still cannot open mpeg2 files in tmpgenc. If I open them in WMP, the play in slow motion with no sound. If I open it in ATI MMC 7.1's file player, the file is very dark and corrupted.
Here's my setup:
ATI AIW 128
Athlon 750
256k Ram
Windows 98 SE
I'm really at my wits end here, I think I've done what most posts suggested. Maybe something is wrong with the way the programs are installed on my machine?
Thanks guys
I just tried a capture using MMC 7.1 VCD setting which of course is mpeg1 and it works fine, so this is definately an mpeg2 problem only.
You can bypass the problems by using DVD2AVI. This is where the VFAPI stuff comes in. Open the .mpg in DVD2AVI and save the project as filename.d2v. You can the open this file in MTPGENC if everything is registered properly ( can be checeked under environment options look for d2v project loader ).
Cheers.
Best results with Open Source Codecs?
By aahamm in forum Video ConversionReplies: 9Last Post: 3rd Feb 2012, 17:56 -
Is there any way to get Vegas Pro 9 to open mp4 with mp4v/mp4a codecs?
By Thunderhead2772 in forum EditingReplies: 7Last Post: 25th Nov 2011, 16:56 -
How to use "Open Codecs" (Xiph.org) DSF?
By _hunter in forum Software PlayingReplies: 0Last Post: 3rd Jan 2011, 13:10 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
