Hi !
From a 5.1 .ac3 file, I want to convert only the rear channels to a .wav file.
I can't find the right process to do it (I'm using Azid/AzidGUI).
Do I need another software ?
Thnaks
Try Sonic Foundry Soft encode. It is pretty easy to use although converting ac3 to wav or visa versa is a bit time consuming.
Ripping rear audio channels only from DVD
By bradg84 in forum AudioReplies: 7Last Post: 15th Aug 2011, 01:27 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28 -
rear projection looks like convergence is off but it's not..
By BroomQueen in forum DVB / IPTVReplies: 0Last Post: 9th Dec 2009, 20:45 -
Need solution on my New Rear Projection TV
By tony1960 in forum DVB / IPTVReplies: 14Last Post: 15th Jul 2008, 19:36 -
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 00:34
