wuts the diff if i use REMPEG over TMPGENC or a CCE program its seems that REMPEG is easy enough.. or is there an extra options between the latter 2 proggies.. or may they are faster? thx
With regards to mpeg2 encoding:
Rempeg is free and simple, but only average quality and VERY slow.
TMPGEnc is inexpensive, very good quality and average speed, but I find the average bitrate settings are not accurate at all. This means it might take you awhile to get used to the program and how to choose "fake" settings to get the desired results. Then again, maybe someone that knows the program better will be able to show you how to use it
CCE has excellent quality and is VERY fast, but it is expensive.
I have used all 3 programs (rempeg2->tmpgenc->cce) and haven't looked back once I figured out how to use CCE.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04
