im trying to clip commercials out of an avi i captured. but when i use virtualdub to clip the avi, it becomes corrupted and wont run. so i was told i should use avisynth the clip out the commercials but i dont know how. can anyone explain it as basic as possible, or tell me where a walkthrough is?
"Vengeance is mine." -God
What codec did you use... it makes a HUGE diffrence on how to edit the files.
Go back to VDub... only this time follow these simple directions.
You can start a cut ANYWHERE, but you must end a cut in a specific location. To find that location go to where you want to end the cut then use the PREVIOUS KEYFRAME button ( should look like a key point to the left ) now go back one more frame and end the cut there.
Good, now save with video/direct stream copy and save your eddited .avi.
These procedures save you from having to re-encode, but may result in poor cut position since you cannot guarntee where the new clip will start ( since you are at the mercy of the keyframe ). You can improve this by reducing the keyframe interval ( in your capture settings ). -
i used the picvideo jpeg codec to encode... and i dont really want to do it the keyframe way if it isnt utterly necessary because i'd prefer to try and take the commercial out right at the correct frame...
also, i cant find where the capture setting is where i can change the keyframe intervals"Vengeance is mine." -God -
red:
I also use PIC MJPEG and have never had any problems cutting and editting using Vdub. Could you explain what you mean by corrupted? Mabye you have a bad playback codec? Can you re-open it in Vdub? -
With mjpeg, every frame is a keyframe, so you may cut wherever you wish and still use direct stream copy
Good times.
BTW, huffy owns mjpeg and is free.
AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]
By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 05:27 -
applying different filters to different sections in a clip (via avisynth)
By unclescoob in forum RestorationReplies: 28Last Post: 30th Jan 2012, 13:50 -
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 09:31 -
Transition from Clip to Clip in Premier
By Namrepus221 in forum EditingReplies: 2Last Post: 1st May 2008, 16:29 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 08:26
