I used DVDX to convert Scorp King and it was narrated by the "Rock" how do you remove the narration and keep the movie?
thanks in advance for the info.
D. Venom
Most high end DVD movies have multiple sound tracks. You obviously chose the wrong track when you converted.
5 or 10 minute test samples before encoding the whole movie can help prevent things like this.There's not much to do but then I can't do much anyway. -
Ok but I used the same track and under audio track in DVDx I used the english 2 ch 0x80, the second time I used the english 2 ch 0x82 and the director did the narrating. I'm lost at this point.
I've found that some titles will only have an AC3 or DTS track and use 2 channel tracks for french and documentary BS, Especially on a lengthy movie and where they have both DTS and AC3. You may have to extract the AC3 track and down-convert to two channel (if that's what you want to end up with).
