dvd shocking. I've created a dvd RW with three avi that I converted into mpeg using TMPGEnc. I used the DVD pal template, 1:1 VGA and full screen keep aspect ratio and a constant bitrate.
The dvd plays fine on my home dvd player including all the menus that i created with Ulead moviemaker but when I play the movie, there are sometimes shocks visible. There not BIG shock, just very small once.
I can see the movie fine, but it would be a BIG improvement if I where to be able to get rid off these shocks.
Any help would be appriciated
Results 1 to 9 of 9
Besides good snti-static protection? 8)
Seriously... what do you mean by "shocking" I can't even begin to imaging what artifact or glitch you are referring to. Are you trying to say Shake? -
i guess he means blocks.... set motion search to highest to fix it. and use floating point on the ?advanced? tab
By shokking I mean that the video tends to hang for a fraction of a second when I play it on my home dvd player. Now, when I say "tend"...it tends a lot
. Every few seconds, the image "freezers" for a fraction of a second.
The original AVI is not of top quality, but the avi doesn't have this when I play it on the PC. -
If this hapens with interlaced video not in fast zooms/pans (strobe effect) or with progressive video, most common problem is bad media/weak reader.
I'm inclined to agree with EPO - your player probably doesn't like the type of media you are using. You could try others (especially CD-RW), but your player may not be entirely compatiable with CD-R media.
I struggled with the same problem and using TMPGenc with several different settings did not bring solution. Than I tryed Panasonic MPEG encoder and YESS!!! I got rid of the nerving stroboscobe effect. Now the sound became out of sync with the latter program so I decided to save the sound in wav format first with Virtualdub, before encoding. Resulting in a smooth stream and no out of sync sound problems. Btw Starting my burning career only last weekend, I already wasted a lot of CD's before having succes. Now I will do a tryout on a rewritable first
All procedures ass described in my message can be found on this site. I hope it has been of help. Let's keep the conversation going
Birima ® -
As I am pretty sure that that it is NOT my home dvd player, I'm going to try encoding the file in a different way by using Panasonic MPEG encoder. The dvd player is a brand new sony and it plays, to my amazement, EVERY possible media: CD,CDRW,CDR(even the cheapest ones!!!),DVD,DVDR,DVDRW,MINIDVD,VCD and SVCD. It's unbelievable and the Sony only costed about 210 EURO!!!
I'll keep you guys posted!!
Jb_Ke
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 07:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29 -
How to post an image instead of a link to image?
By fLYtRap in forum FeedbackReplies: 11Last Post: 5th Jul 2007, 12:55
