I own one of the set top DVD players that forces me to use the Svcd header trick in order to play Svcd's
header tirck info here
anyway, TMPGEnc usuaily works great and the svcd's play great on my player, but i am having a problem with a few .mpeg's that a friend sent me. TMPGEnc wont finish and the result file is only like 500-600mb when it should be 750-800mb. the completion bar on TMPGEnc goes slowly, then when its about 2/3 done it jumps to 100%. When watching the result file, it ends early. I also tryed running the .mpeg thru vcdgear to try to fix any .mpeg errors but still get an incomplete file.
anyone have any ideas on a way to fix this? or maby another program other than TMPGEnc that may work?
One topic is ENOUGH.
If the mpeg is corrupt this usually happens...search in our forums for demultiplex problems with tmpgenc.
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 05:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 09:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21
