  1. hi, I am trying to rip this movie and when I try using smartripper and gave a lock vob file and when I open power dvd it did unlock and I use stream processing and the program stop at 69% and it stayed there.....then I tried using dvd decryptor, same stream processing , then at 58% it gave me an error..
    How can I get thru the lock vob....
    any help is much appreciated....
    Oct 2002
    south wales
    You need to change the settings on the ripping. Default is auto - change it normal and all will be rosy!
    I've ripped it no problem.
    Failing that, try claddvd xp.
    Do not use Stream Processing either.
  3. I just made a perfect copy of High Crimes to DVDR
    http://www.vcdhelp.com/forum/viewtopic.php?t=116661&highlight=
    Used DVD decrypter and followed this guide
    http://www.vcdhelp.com/forum/viewtopic.php?p=315500&highlight=#315500
  4. markc32, which ripper are you talking about????? smart ripper or dvd decryptor.. I check dvd decryptor and there is no setting like that ..
    can somebody tell me which program to use and what are the step..
    thanks
  5. Originally Posted by freebee22
    can somebody tell me which program to use and what are the step..thanks
    Hello?, I think I just did above.
    You have to leave out the "end credits" as the movie part
    is just over 100mb to big.
