I am trying to figure out the best way to grab a still frame from an mpeg file. I understand that it will probably have to be an i-frame. does anyone know what software can accomplish this in the least bloatware way?
also, if i have an mpeg still file, does anyone know how I can convert that to a jpeg (or other) file? I imagine the same software that will solve the former will also solve the latter?
thanks in advance!
ll
you can do this with powerdvd , windvd , tmpgenc
if windvd - just hit the camera button at the frame you want
if tmpgenc - set source range where you want to capture and then file save as frmes .
powerdvd is about the same as windvd
if you want to convert a lot of frames - tmpgenc is the best really, just save as frames
MPEG I-frames to JPEG
By bluethunder888 in forum ProgrammingReplies: 13Last Post: 9th Jul 2011, 18:54 -
extracting jpeg frame by frame from video
By goofymickey in forum ProgrammingReplies: 0Last Post: 16th Dec 2010, 08:02 -
Saving a single Frame as a Jpeg
By acestu in forum EditingReplies: 0Last Post: 20th Aug 2008, 16:11 -
Add JPEG as First Frame - Windows Explorer Preview - Without Reencoding..
By aces27 in forum EditingReplies: 1Last Post: 28th Feb 2008, 10:07 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
