I was wondering is rencoding needed to change the DAR(direct aspect ratio) of an mpeg 2 file or is there another way'?
I have a load of cvds ready for conversion to dvd but most are anamorphic but the sapect ratio is 4:3 This means I have to select widescreen on my tele myself.
Whjen I convert to dvd can I make them anamorphic without reencoding?
Help greatly appreciated.
Baker
No reencoding is required. You can change aspect ratio with some mpeg tools and also set anamorphic in the authoring tools.
baker-
this thread might be applicable:
http://www.vcdhelp.com/forum/viewtopic.php?t=116788
essentially, have you tried using these two utilities yet?:
DvdPatcher http://mitglied.lycos.de/dvdpatcher/
ReStream http://shh.dvdboard.de/
-s. -
Pulldown.exe will allow you to change the DAR on an MPEG, among other things. You can get a copy installed with DVD2SVCD (see the TOOLS section on the left), or do a search on GOOGLE for PULLDOWN.EXE if you don't want to download the whole DVD2SVCD package.
There's a GUI for it available too, but I can't recall where I found mine.Impossible to see the future is. The Dark Side clouds everything...
Change Aspect Ratio without re-encode
By 80r in forum Video ConversionReplies: 2Last Post: 27th Jun 2011, 13:59 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 11:33 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 12:01 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 14:14 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 10:21
