    Teegeack
    In NT you can right click choose properties, and it will tell you the audio bit rate of a DIVX.
    In Win 2K that is not the case. Same with XP from what I hear.
    I have a few divx that I downloaded, and they are like 720 MB. I do not want to overburn.
    I wanted to futz around with the file to make it smaller. One way I have doe this in the past is by changing the bit rate from like 320 KB/sec to 112. Save a ton of space. However, on my WIN2K box, I can't figure out what the bit rate is for the DIVX. I know it is an MP3 because Virtual Dub has it as a Fraunhoffer MPEG 3 or something.
    Anyone know of a tool or a way I can determine the audio bit rate?
    Thanks!
    Feel free to instant message me...
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    OPen the clip in VIrtualDub - go to FILE - FILE INFORMATION
    to re-encode to avi, set up both your video comppression and filters under the Video heading, and set up your Audio conversions and Compressions under Audio
    Both areas set to FULL PROCESSING MODE
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
    Teegeack
    tHANKS, BUT THERE IS NO BIT RATE INFO THAT i CAN SEE IN file information. Any other ideas??
