I need some help here. Im using the DVD2AVI method to backup my DVD and convert it to VCD (The Mummy). I did the D2v file on DVD2AVI but TMPGEnc tells me the format is not recognizable (the d2v that is). I installed the VFAPI plug in for TMPGEnc. But it doesn't seem to work anyway.
SOMEBODY HEELLPPPP!!!!!
you gotta run the dvd2avi.vfp file in both directories of dvd2avi.exe and tmpg.exe, that should fix it
Thanks alot moneyman13. It fixed the problem
This should be posted on the guides. No much people know this.
<font size=-1>[ This Message was edited by: Boooooommm on 2001-08-18 08:46:04 ]</font> -
I own a Sigmadesigns dvr. And my problem is with MPEG2 files. If I recored them into a MPEG file or a elemantary file TMPGEnc comes back with a error"cannot acess file or file not supported". Did anyone ever see this problem before? Meg1 files into TMPGEnc seems to work ok but the card does't do a good MPEG1 capture.
I own a Sigmadesigns dvr. And my problem is with MPEG2 files. If I record them into a MPEG file or a elemantary file TMPGEnc comes back with a error"cannot acess file or file not supported". Did anyone ever see this problem before? Meg1 files into TMPGEnc seems to work ok but the card does't do a good MPEG1 capture.
gf: please post a new topic instead...and not in this dvd ripping forum
moneyman13: I dont have the dvd2avi.vfp in both directories and it has always worked. But I can add it to problems sections to sefys dvd2avi guide. -
Final chime in before the thread gets closed.. Check and see if all the VOBs are there, which are listed in the .D2V file, if not TMPGEnc cant load the .D2V file.. I know, found out the hard way... Dont know, but maybe your problem is there?
HTH
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
can't open mpegs made over 5 years ago - used tmpg
By heidihagen in forum Authoring (VCD/SVCD)Replies: 3Last Post: 20th Mar 2009, 14:40 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
