is there a progame to make the qwality of a movie better to make the movie clear thnks 8)
Whay type of movie are you referring to? vcd, svcd, divx,
Please list some more info -
dont list to much info there
dont say what its coming from or what software you have tried. that might give us too much information to help ya! -
ow sory i tried tmpgenc to convert avi to vcd but the qwality of that vcd is not very clear and i want to clear it so the qwality gets more clearly thnks 8)
First suggestion is (if you can) make it an SVCD. if your dvd player will play an SVCD i suggest you make that instead, they look better than vcd's. Remeber that the movie you make can not look any better than the avi its coming from, its impossible.
Some suggestions in tmpgenc. Change motion search to High Quality, if your dvd player will play xvcd then raise the bitrate to improve the quality.
without seeing the source it would be hard to give too many suggestions on what filters to use.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 18th Jan 2012, 23:11 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 01:13 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
